Bought another console! Pictures added!
Not familiar with how to get the "thumb nail" pictures added but will try. If I bomb out, will go the photobucket approach.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...0001-4.jpg]
[Image: http://i303.photobucket.com/albums/nn129...0005-2.jpg]
[Image: http://i303.photobucket.com/albums/nn129...0004-4.jpg]
[Image: http://i303.photobucket.com/albums/nn129...0003-3.jpg]
RE: Bought another console! - by codefox1 - 07-05-2012, 11:26 PM
RE: Bought another console! - by TA Forbes - 07-06-2012, 01:06 PM
RE: Bought another console! - by jerryhawthorne - 07-06-2012, 03:07 PM
Philco 91 Tuning Condenser
There are currently 5893 online users. [Complete List]
» 3 Member(s) | 5890 Guest(s)
