40-88 battery
Chris, if indeed it is a 90/1.5 V battery is is quite easy and inexpensive to build an A/C power supply and incase it in a box. Cover with graphics and it looks stock, other than an A/C cord coming out with an in-line switch on it.
I have done 2 of these and they were fun to build. Maybe $30 for all parts, most for the aluminium box and the the board. The other option is to buy a bunch of nine volt batteries and hook together for a total of 90V and a couple C cells for the 1.5. I always thought that was messy and I don't like replacing batteries. Attached is a pix of what I made for a couple of farm radios.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...Radio2.jpg]
40-88 battery - by Philcofan - 07-02-2012, 12:35 PM
RE: 40-88 battery - by jerryhawthorne - 07-06-2012, 06:25 PM
RE: 40-88 battery - by 7estatdef - 07-06-2012, 07:32 PM
RE: 40-88 battery - by jerryhawthorne - 07-08-2012, 05:16 PM
RE: 40-88 battery - by 7estatdef - 07-08-2012, 06:33 PM
RE: 40-88 battery - by Ron Ramirez - 07-08-2012, 08:09 PM
The speaker table error?
Philco 70 antenna lead
