Philco 37-62 electrolytic voltage
Didn't see a voltage listed for power caps, Philco 37-62.
I'm guessing 400 volts.
Thanks. Icon_clap
Philco 37-62 electrolytic voltage - by FXpert - 07-07-2012, 07:29 AM
RE: Philco 37-62 electrolytic voltage - by FXpert - 07-07-2012, 10:35 AM
Philco 91 Tuning Condenser
There are currently 5354 online users. [Complete List]
» 1 Member(s) | 5353 Guest(s)
