Cone sentric tuning questions
Just the spring that slips on first. That knerl on my 38-4 only seems to work turning clockwise while pushing inward. It barely grips the bezel. Try to adjust the bezel/dial toward the left a hair.
Tune in your stations and lock the cones. I never had to adjust them after that.
Cone sentric tuning questions - by tubadon40 - 07-06-2012, 10:42 PM
RE: Cone sentric tuning questions - by FXpert - 07-07-2012, 07:20 AM
RE: Cone sentric tuning questions - by tubadon40 - 07-07-2012, 12:48 PM
RE: Cone sentric tuning questions - by Chicago Jimmy - 07-07-2012, 07:23 PM
RE: Cone sentric tuning questions - by tubadon40 - 07-07-2012, 07:27 PM
RE: Cone sentric tuning questions - by tubadon40 - 07-09-2012, 05:06 PM
Philco 91 Tuning Condenser
There are currently 5879 online users. [Complete List]
» 1 Member(s) | 5878 Guest(s)
