Model 640 restoration questions.
Re-build the bakelite block caps too. Also perform a full alignment per the instructions for best reception and shadow meter action.
See the easy steps from my site:
[Image: http://www.philcorepairbench.com/images/bblok-01.jpg]
• BAKELITE BLOCK RE-BUILDING •
Also see the Service Tips section for Shadow Meter info and Model 640 Dial Drive info.
Chuck
Model 640 restoration questions. - by Guest - 03-23-2007, 02:43 PM
[No subject] - by Chuck Schwark - 03-23-2007, 03:52 PM
[No subject] - by Bill Hutchinson - 03-23-2007, 03:58 PM
[No subject] - by Guest - 04-02-2007, 02:09 PM
The band that doesn't work...... - by AI2V - 04-02-2007, 07:48 PM
[No subject] - by Bill Hutchinson - 04-04-2007, 03:41 PM
[No subject] - by Guest - 04-05-2007, 08:09 PM
[No subject] - by planigan - 04-14-2007, 01:32 AM
There are currently 10388 online users. [Complete List]
» 3 Member(s) | 10385 Guest(s)
