My tallest Philco console
Quote:BZZZZZZZZZZZZZZZZTT!!! There goes the antenna coil.
Maybe that's what happened. On the antenna coil, the outside coil seems OK, but the lower inside coil is open. Also, the 20 ohm, wire wound resistor mounted on the coil is burned away. I have contacted Ron.
My tallest Philco console - by DKinYORKpa - 07-01-2012, 04:57 PM
RE: My tallest Philco console - by Michael Gerber - 07-01-2012, 05:04 PM
RE: My tallest Philco console - by Philament - 07-01-2012, 06:31 PM
RE: My tallest Philco console - by Arran - 07-01-2012, 08:01 PM
RE: My tallest Philco console - by Ron Ramirez - 07-01-2012, 08:29 PM
RE: My tallest Philco console - by Philament - 07-01-2012, 08:57 PM
RE: My tallest Philco console - by Arran - 07-01-2012, 11:01 PM
RE: My tallest Philco console - by PhilcoMike - 07-02-2012, 11:32 AM
RE: My tallest Philco console - by GuyIncognito - 07-02-2012, 12:52 PM
RE: My tallest Philco console - by 7estatdef - 07-02-2012, 01:20 PM
RE: My tallest Philco console - by Ron Ramirez - 07-02-2012, 03:42 PM
RE: My tallest Philco console - by TA Forbes - 07-02-2012, 04:53 PM
RE: My tallest Philco console - by Arran - 07-02-2012, 05:36 PM
RE: My tallest Philco console - by Ron Ramirez - 07-02-2012, 06:27 PM
RE: My tallest Philco console - by DKinYORKpa - 07-02-2012, 07:45 PM
RE: My tallest Philco console - by Ron Ramirez - 07-02-2012, 08:05 PM
RE: My tallest Philco console - by Philament - 07-02-2012, 08:35 PM
RE: My tallest Philco console - by DKinYORKpa - 07-08-2012, 02:52 PM
RE: My tallest Philco console - by Ron Ramirez - 07-08-2012, 08:25 PM
Philco 91 Tuning Condenser
There are currently 3433 online users. [Complete List]
» 1 Member(s) | 3432 Guest(s)
