37-116 Help
Hello Bill:
I just re-capped my 37-116X manual tuning. I think you should check that C123, the 10 micro farad electrolytic cap, is wired in with the correct polarity as shown in the schematic. In fact, you should check that all the electrolytics have the schematic's polarities. The schematic is correct. Also, there is a production change which changes C126 and C127 from 8 to 4 micro farads each. I hope this helps.
William
37-116 Help - by Guest - 03-23-2007, 09:54 PM
Re: 37-116 Help - by n9vu - 03-24-2007, 06:36 AM
37-116 Help - by William - 03-24-2007, 09:31 AM
Fixed! - by Guest - 03-24-2007, 09:34 PM
There are currently 8127 online users. [Complete List]
» 5 Member(s) | 8122 Guest(s)
AvatarAvatarAvatarAvatar
