My New Philco 15x
A belated welcome, Jon! And congratulations on your acquisition of one of Philco's neatest consoles. When you have it all finished, you'll like how the grille area lights up when the set is on (assuming you install a new appliance bulb in place).
As Bob (bandersen) told you previously, the original power transformer was vertical mounting, part no. 6672. Here are the specs:
Primary 110-115 volts, 60 cycle AC
High Voltage Secondary: 720 VCT @ 145 mA DC
Filaments: 6.3VCT @ 5 A
Rectifier Filament: 5V @ 2A
If you can't find an original, a Hammond 274BX will work - be aware that its B+ (high voltage) is somewhat higher at 750 VCT but this will translate to roughly 15 volts more B+. This can be left alone, or compensated for with a dropping resistor. The 5V and 6.3V windings have higher current capability (always a good thing), but note that the 5V winding in the Hammond has a center tap which will be unused and will need to be carefully taped off.
My New Philco 15x - by Philco281989 - 06-28-2012, 04:54 PM
RE: My New Philco 15x - by Glenn Roberts - 06-28-2012, 06:06 PM
RE: My New Philco 15x - by Philco281989 - 06-28-2012, 06:24 PM
RE: My New Philco 15x - by Philco281989 - 06-28-2012, 06:44 PM
RE: My New Philco 15x - by 37silverstreak - 06-28-2012, 07:21 PM
RE: My New Philco 15x - by Philco281989 - 06-28-2012, 10:48 PM
RE: My New Philco 15x - by Bob Andersen - 06-29-2012, 12:24 AM
RE: My New Philco 15x - by Philco281989 - 06-29-2012, 08:49 AM
RE: My New Philco 15x - by Bob Andersen - 06-29-2012, 08:26 PM
RE: My New Philco 15x - by Philco281989 - 06-29-2012, 08:43 PM
RE: My New Philco 15x - by Arran - 06-29-2012, 09:08 PM
RE: My New Philco 15x - by Philco281989 - 06-29-2012, 09:48 PM
RE: My New Philco 15x - by Arran - 06-29-2012, 11:34 PM
RE: My New Philco 15x - by Bob Andersen - 06-30-2012, 07:33 PM
RE: My New Philco 15x - by CrumblingWires - 06-30-2012, 09:42 PM
RE: My New Philco 15x - by Philco281989 - 06-30-2012, 09:52 PM
RE: My New Philco 15x - by Bob Andersen - 07-01-2012, 02:50 PM
RE: My New Philco 15x - by Philco281989 - 07-01-2012, 03:43 PM
RE: My New Philco 15x - by Ron Ramirez - 07-11-2012, 04:19 PM
Philco 91 Tuning Condenser
There are currently 5349 online users. [Complete List]
» 1 Member(s) | 5348 Guest(s)
