Majestic 71
Doesn't that power supply have a ballast? I think that the input voltage is 80V. You can use a light bulb to drop yout line voltage as well.
Majestic 71 - by Jayce - 07-15-2012, 10:10 PM
RE: Majestic 71 - by Arran - 07-16-2012, 03:40 AM
RE: Majestic 71 - by Phlogiston - 07-16-2012, 10:56 AM
RE: Majestic 71 - by Jayce - 07-16-2012, 03:38 PM
Philco 91 Tuning Condenser
There are currently 6885 online users. [Complete List]
» 2 Member(s) | 6883 Guest(s)
