9S262 - getting started
#60
As for the GND connection, on the page 3 look at the bottom vie. of the chassis, see the arched green wire in between the two teminal strips, and from one of the terminals it goes to you will see the shiny band going to chassis, I imply stripped the wire and press it between the strip and the chassis which is unpainted brass or copper. Makes for a good Gnd connection.
9S262 - getting started - by morzh - 05-12-2012, 06:02 PM
RE: 9S262 - getting started - by morzh - 05-12-2012, 06:04 PM
RE: 9S262 - getting started - by Gene Pederson - 05-12-2012, 07:57 PM
RE: 9S262 - getting started - by morzh - 05-12-2012, 10:57 PM
RE: 9S262 - getting started - by morzh - 05-13-2012, 04:57 PM
RE: 9S262 - getting started - by codefox1 - 05-14-2012, 01:42 PM
RE: 9S262 - getting started - by morzh - 05-14-2012, 02:58 PM
RE: 9S262 - getting started - by Gene Pederson - 05-14-2012, 03:48 PM
RE: 9S262 - getting started - by Chuck Schwark - 05-14-2012, 04:53 PM
RE: 9S262 - getting started - by codefox1 - 05-14-2012, 04:55 PM
RE: 9S262 - getting started - by morzh - 05-14-2012, 06:19 PM
RE: 9S262 - getting started - by codefox1 - 05-14-2012, 07:31 PM
RE: 9S262 - getting started - by morzh - 05-14-2012, 11:26 PM
RE: 9S262 - getting started - by Arran - 05-15-2012, 10:36 PM
RE: 9S262 - getting started - by morzh - 05-16-2012, 09:53 AM
RE: 9S262 - getting started - by morzh - 05-19-2012, 09:46 PM
RE: 9S262 - getting started - by TA Forbes - 05-19-2012, 09:57 PM
RE: 9S262 - getting started - by morzh - 05-19-2012, 11:05 PM
RE: 9S262 - getting started - by morzh - 05-19-2012, 11:08 PM
RE: 9S262 - getting started - by Gene Pederson - 05-20-2012, 11:39 PM
RE: 9S262 - getting started - by morzh - 05-21-2012, 10:32 AM
RE: 9S262 - getting started - by rocketeer - 05-21-2012, 10:45 AM
RE: 9S262 - getting started - by morzh - 05-21-2012, 11:28 AM
RE: 9S262 - getting started - by rocketeer - 05-21-2012, 04:23 PM
RE: 9S262 - getting started - by morzh - 05-21-2012, 09:31 PM
RE: 9S262 - getting started - by Gene Pederson - 05-21-2012, 10:24 PM
RE: 9S262 - getting started - by morzh - 05-22-2012, 11:12 PM
RE: 9S262 - getting started - by morzh - 05-27-2012, 12:02 PM
RE: 9S262 - getting started - by morzh - 05-27-2012, 12:05 PM
RE: 9S262 - getting started - by morzh - 06-09-2012, 09:54 PM
RE: 9S262 - getting started - by TA Forbes - 06-10-2012, 02:14 PM
RE: 9S262 - getting started - by codefox1 - 06-10-2012, 03:22 PM
RE: 9S262 - getting started - by morzh - 06-10-2012, 04:30 PM
RE: 9S262 - getting started - by rocketeer - 06-13-2012, 10:39 AM
RE: 9S262 - getting started - by morzh - 06-15-2012, 09:57 PM
RE: 9S262 - getting started - by morzh - 06-15-2012, 10:09 PM
RE: 9S262 - getting started - by rocketeer - 06-16-2012, 08:28 AM
RE: 9S262 - getting started - by morzh - 06-16-2012, 10:59 AM
RE: 9S262 - getting started - by morzh - 06-29-2012, 12:32 AM
RE: 9S262 - getting started - by morzh - 06-30-2012, 04:51 PM
RE: 9S262 - getting started - by morzh - 06-30-2012, 05:09 PM
RE: 9S262 - getting started - by morzh - 06-30-2012, 11:02 PM
RE: 9S262 - getting started - by jth877 - 07-11-2012, 05:09 PM
RE: 9S262 - getting started - by morzh - 07-12-2012, 09:29 PM
RE: 9S262 - getting started - by morzh - 07-12-2012, 09:34 PM
RE: 9S262 - getting started - by jth877 - 07-13-2012, 12:48 PM
RE: 9S262 - getting started - by morzh - 07-13-2012, 07:29 PM
RE: 9S262 - getting started - by Arran - 07-13-2012, 09:00 PM
RE: 9S262 - getting started - by morzh - 07-14-2012, 11:39 AM
RE: 9S262 - getting started - by Arran - 07-14-2012, 08:34 PM
RE: 9S262 - getting started - by jth877 - 07-15-2012, 11:08 AM
RE: 9S262 - getting started - by morzh - 07-15-2012, 11:51 AM
RE: 9S262 - getting started - by jth877 - 07-15-2012, 08:38 PM
RE: 9S262 - getting started - by codefox1 - 07-15-2012, 11:35 PM
RE: 9S262 - getting started - by jth877 - 07-16-2012, 12:34 AM
RE: 9S262 - getting started - by codefox1 - 07-16-2012, 08:49 AM
RE: 9S262 - getting started - by morzh - 07-16-2012, 09:22 AM
RE: 9S262 - getting started - by jth877 - 07-16-2012, 10:30 AM
RE: 9S262 - getting started - by morzh - 07-16-2012, 07:43 PM
RE: 9S262 - getting started - by morzh - 07-16-2012, 07:50 PM
RE: 9S262 - getting started - by jth877 - 07-16-2012, 10:28 PM
RE: 9S262 - getting started - by morzh - 07-16-2012, 11:05 PM
RE: 9S262 - getting started - by jth877 - 07-17-2012, 09:40 AM
RE: 9S262 - getting started - by morzh - 07-17-2012, 08:10 PM
RE: 9S262 - getting started - by morzh - 07-17-2012, 08:11 PM
RE: 9S262 - getting started - by rocketeer - 07-17-2012, 09:20 PM
RE: 9S262 - getting started - by morzh - 07-17-2012, 11:34 PM
RE: 9S262 - getting started - by rocketeer - 07-18-2012, 02:08 PM
RE: 9S262 - getting started - by morzh - 07-18-2012, 08:48 PM
RE: 9S262 - getting started - by jth877 - 07-19-2012, 10:27 AM
RE: 9S262 - getting started - by morzh - 07-19-2012, 10:33 AM
RE: 9S262 - getting started - by rocketeer - 07-19-2012, 11:19 AM
RE: 9S262 - getting started - by morzh - 07-19-2012, 12:03 PM
RE: 9S262 - getting started - by jth877 - 07-19-2012, 01:35 PM
RE: 9S262 - getting started - by morzh - 07-19-2012, 02:34 PM
RE: 9S262 - getting started - by codefox1 - 07-19-2012, 07:39 PM
RE: 9S262 - getting started - by rocketeer - 07-19-2012, 08:21 PM
RE: 9S262 - getting started - by morzh - 07-19-2012, 08:39 PM
RE: 9S262 - getting started - by morzh - 07-22-2012, 11:10 AM
RE: 9S262 - getting started - by morzh - 09-01-2012, 05:00 PM
RE: 9S262 - getting started - by morzh - 09-03-2012, 11:47 AM
Users browsing this thread: 17 Guest(s)
There are currently 8373 online users. [Complete List]
» 2 Member(s) | 8371 Guest(s)
