Need Dial Scale for Grundig Model 1088
I recently acquired a Grundig Majestic 1088. The seller did a poor job of packing it and the radio arrived with the glass dial scale smashed.
It happens that I just restored a Grundig Majestic 2028 and it uses the exact same dial scale. So I took a high resolution scan of it.
Does anyone know of a source that can reproduce the dial scale with my file or print out some type of decal that I could install over a piece of glass?
I found one source but they couldn't do a scale this big - it's 16" wide by 3" high.
Thanks!
Need Dial Scale for Grundig Model 1088 - by Jack - 07-16-2012, 09:40 PM
There are currently 7267 online users. [Complete List]
» 1 Member(s) | 7266 Guest(s)
