  • 1 Vote(s) - 5 Average
Zenith 9-S-262 Restoration Chronicles
I used standard rubber grommets to replace the dried, falling apart grommets that go between the tuning condenser and the metal support bracket that holds it.
Manufacturer: Philmore
1/4" x 3/8"
No. 10-048
They turned out to be a perfect fit but the rubber is a little harder than the originals. Some of the original was still intact and it felt like gum rubber. These should work out fine though.
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=2]
- Geoff
Zenith 9-S-262 Restoration Chronicles - by Geoff - 06-28-2012, 12:56 AM
RE: Zenith 9-S-262 Restoration Chronicles - by Geoff - 07-17-2012, 12:52 AM
Users browsing this thread: 16 Guest(s)
There are currently 3441 online users. [Complete List]
» 1 Member(s) | 3440 Guest(s)
