Philco Model 048 Tester
Thanks Chuck....the order is placed and check is in the mail
Philco Model 048 Tester - by bm071 - 07-16-2012, 08:36 PM
RE: Philco Model 048 Tester - by Ron Ramirez - 07-16-2012, 09:44 PM
RE: Philco Model 048 Tester - by Chuck Schwark - 07-16-2012, 10:00 PM
RE: Philco Model 048 Tester - by bm071 - 07-17-2012, 08:07 PM
RE: Philco Model 048 Tester - by Chuck Schwark - 07-17-2012, 09:11 PM
The speaker table error?
Philco 70 antenna lead
