A Beginner's Journey: The Philco 40-190
Superglue, no. Two-part clear epoxy, maybe. (EDIT: I should have been paying closer attention...or I shouldn't post after driving all afternoon and part of the evening. You are referring to the center key, correct? Forget about it. Replace the socket.)
Your 6J8 socket is sort of tan in color, compared to the dark brown of your other sockets, yes? I ran into the same problem with two of the tube sockets in my 41-616. That tannish color material Philco used to make some of their sockets during 1940-41 is very prone to breakage. The brown wafer sockets are much, much better than those.
RE: A Beginner's Journey: The Philco 40-190 - by Ron Ramirez - 07-21-2012, 11:41 PM
Users browsing this thread: 21 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
