WHICH 690 IS BEST BET?
Arran Wrote:Personally I think that there should be a rule on such forums that if you post something for sale, and it sells, you should announce that it's gone and remove the ad, or get a reprimand of some sort.
While I agree with you, as the owner of this website and Phorum I also have to walk a fine line between enforcing rules and ticking people off. Make someone mad, they go over to the other forum, you never hear from them again. So I just depend on folks to be honest and to post when their item sells. Sale and wanted ads are pulled after 30 days here anyway, I see no need in archiving them forever as they do at ARF. To me, archiving all ads is a big waste of bandwidth and hard drive space. Chances are that Fliminjammer XT-800 35-tube radio posted for sale in 1996 is no longer available. Icon_rolleyes
WHICH 690 IS BEST BET? - by Sam samuelian - 06-13-2012, 07:31 AM
RE: WHICH 690 IS BEST BET? - by codefox1 - 06-13-2012, 02:01 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 06-13-2012, 04:41 PM
RE: WHICH 690 IS BEST BET? - by Sam samuelian - 06-13-2012, 04:50 PM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 06-13-2012, 09:32 PM
RE: WHICH 690 IS BEST BET? - by Arran - 06-14-2012, 12:57 AM
RE: WHICH 690 IS BEST BET? - by 7estatdef - 06-14-2012, 03:59 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 06-14-2012, 08:45 PM
RE: WHICH 690 IS BEST BET? - by Arran - 06-14-2012, 09:41 PM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 06-15-2012, 07:51 PM
RE: WHICH 690 IS BEST BET? - by Jayce - 06-15-2012, 08:00 PM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 06-15-2012, 09:35 PM
RE: WHICH 690 IS BEST BET? - by Arran - 06-16-2012, 03:01 AM
RE: WHICH 690 IS BEST BET? - by Jayce - 06-16-2012, 03:44 PM
RE: WHICH 690 IS BEST BET? - by codefox1 - 06-16-2012, 11:41 PM
RE: WHICH 690 IS BEST BET? - by Sam samuelian - 06-19-2012, 01:09 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 06-20-2012, 05:40 AM
RE: WHICH 690 IS BEST BET? - by Sam samuelian - 07-20-2012, 04:45 AM
RE: WHICH 690 IS BEST BET? - by PhilcoJohn - 07-20-2012, 07:10 PM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 07-20-2012, 10:26 PM
RE: WHICH 690 IS BEST BET? - by Arran - 07-21-2012, 11:11 PM
RE: WHICH 690 IS BEST BET? - by Arran - 07-22-2012, 07:22 AM
RE: WHICH 690 IS BEST BET? - by Ron Ramirez - 07-22-2012, 08:14 AM
RE: WHICH 690 IS BEST BET? - by TA Forbes - 07-22-2012, 10:56 AM
RE: WHICH 690 IS BEST BET? - by Arran - 07-22-2012, 10:51 PM
Philco 91 Tuning Condenser
