Model 640 restoration questions.
Pete,
Actually it's the 2.2-2.6 mc "police band" that's the quiet one. I can hear background noise, but no stations. I'm not sure what, if anything, is on these frequencies today. I can receive a few NDBs located at nearby airports on the 145-390 kc longwave band.
No issues with the 42s yet, but thanks for the info.
Tad
Model 640 restoration questions. - by Guest - 03-23-2007, 02:43 PM
[No subject] - by Chuck Schwark - 03-23-2007, 03:52 PM
[No subject] - by Bill Hutchinson - 03-23-2007, 03:58 PM
[No subject] - by Guest - 04-02-2007, 02:09 PM
The band that doesn't work...... - by AI2V - 04-02-2007, 07:48 PM
[No subject] - by Bill Hutchinson - 04-04-2007, 03:41 PM
[No subject] - by Guest - 04-05-2007, 08:09 PM
[No subject] - by planigan - 04-14-2007, 01:32 AM
There are currently 8723 online users. [Complete List]
» 3 Member(s) | 8720 Guest(s)
