40-180 Questions
There are not really bare there are coated with lacquer. How's the rubber wire? All the tubes good? You should be able to touch the center connection on the volume control and get a blast of hum if all is well with the audio stages.
40-180 Questions - by GaryM - 07-22-2012, 03:07 PM
RE: 40-180 Questions - by 7estatdef - 07-22-2012, 06:36 PM
RE: 40-180 Questions - by GaryM - 07-22-2012, 07:34 PM
RE: 40-180 Questions - by 7estatdef - 07-22-2012, 08:35 PM
RE: 40-180 Questions - by GaryM - 07-22-2012, 10:34 PM
RE: 40-180 Questions - by gary rabbitt - 08-01-2012, 09:34 PM
The speaker table error?
Philco 70 antenna lead
There are currently 3508 online users. [Complete List]
» 1 Member(s) | 3507 Guest(s)
