  • 1 Vote(s) - 5 Average
Now I've done it...One Bucket List set FOUND!
Quote:Yes, the original owner received the privilege of having their name engraved on the manufacturer's tag on the back of the tuner chassis.
I think it would be interesting to have some documentation on the original owner; was it the late parent of the heirs you got it from via estes? Were there other owners in-between? I believe its part of the specific history of that radio, and these models give a rather rare opportunity to look in that direction, compared to non-identified radios...
After all, its part of your bucket list. If it deserves the extra attention of having paper caps restored, maybe it also deserves a little more backstory?
-Mars
RE: Now I've done it...One Bucket List set FOUND! - by Marsupial - 07-23-2012, 12:21 AM
There are currently 9704 online users. [Complete List]
» 1 Member(s) | 9703 Guest(s)
