Bad Output Transformer
John Kendall at http://www.vintage-electronics.com/rjy.htm
has a 42-1008 chassis for parts. You would need to email him to see if he has the output transformer available. If not you could go the universal Hammond transformer route. Radio Daze sells these.
Bad Output Transformer - by Eric T - 07-26-2012, 09:40 PM
RE: Bad Output Transformer - by John R - 07-26-2012, 09:58 PM
RE: Bad Output Transformer - by Arran - 07-27-2012, 07:35 AM
RE: Bad Output Transformer - by Eric T - 07-27-2012, 07:56 AM
RE: Bad Output Transformer - by Eric T - 07-27-2012, 09:22 PM
RE: Bad Output Transformer - by Ron Ramirez - 07-27-2012, 09:37 PM
RE: Bad Output Transformer - by Eric T - 07-27-2012, 09:45 PM
The speaker table error?
Philco 70 antenna lead
