How heavy is a 37-116x?
A reminder germane to this discussion. You never know when a member might be driving a truck with extra space near to your location from where that hard to ship radio is located. If you make your location part of your profile/signature on the left, you could get lucky.
How heavy is a 37-116x? - by SteveJB - 07-26-2012, 09:15 PM
RE: How heavy is a 37-116x? - by 37silverstreak - 07-26-2012, 09:40 PM
RE: How heavy is a 37-116x? - by Glenn Roberts - 07-27-2012, 04:48 AM
RE: How heavy is a 37-116x? - by Ron Ramirez - 07-27-2012, 05:47 AM
RE: How heavy is a 37-116x? - by Arran - 07-27-2012, 05:51 AM
RE: How heavy is a 37-116x? - by Uffda - 07-27-2012, 01:53 PM
RE: How heavy is a 37-116x? - by SteveJB - 07-27-2012, 03:00 PM
Philco 91 Tuning Condenser
