How heavy is a 37-116x?
So does it mount the same as a 38 116?
On that one I have a guide pin in the back center that the screw goes through and the tuner sits in the hole in the cabinet. There are stops in front of the chassis, but no where for them to mount in the cabinet and thats it.
How heavy is a 37-116x? - by SteveJB - 07-26-2012, 09:15 PM
RE: How heavy is a 37-116x? - by 37silverstreak - 07-26-2012, 09:40 PM
RE: How heavy is a 37-116x? - by Glenn Roberts - 07-27-2012, 04:48 AM
RE: How heavy is a 37-116x? - by Ron Ramirez - 07-27-2012, 05:47 AM
RE: How heavy is a 37-116x? - by Arran - 07-27-2012, 05:51 AM
RE: How heavy is a 37-116x? - by Uffda - 07-27-2012, 01:53 PM
RE: How heavy is a 37-116x? - by SteveJB - 07-27-2012, 03:00 PM
Philco 91 Tuning Condenser
