I have been bundled!
Actually, this is the transformerless version of this model. I guess Zenith went through a spree of building both tranformered and transformerless models during this time. Probably makes it even rarer as I have yet to see a picture of one with the gold dial like mine.
I have been bundled! - by Jayce - 07-27-2012, 02:38 PM
RE: I have been bundled! - by TimC - 07-27-2012, 03:31 PM
RE: I have been bundled! - by Jayce - 07-27-2012, 03:52 PM
RE: I have been bundled! - by rocketeer - 07-27-2012, 07:00 PM
RE: I have been bundled! - by Jayce - 07-27-2012, 08:48 PM
RE: I have been bundled! - by Arran - 07-28-2012, 12:36 AM
RE: I have been bundled! - by Jayce - 07-28-2012, 06:13 PM
RE: I have been bundled! - by codefox1 - 07-28-2012, 08:32 PM
Philco 91 Tuning Condenser
There are currently 8189 online users. [Complete List]
» 1 Member(s) | 8188 Guest(s)
