Philco 71 E IF adjustment instability
Well, always could be usual crap or dust amongst the leaves. Why not loosten it up, blast it out with Deoxit, leave it dry over night and try again. Usual stuff, count how many turns accurately to tighten, write down, ad repeat backwards the nest day. Yo'ull be really close.
Hopes this helps.
RE: Philco 71 E IF adjustment instability - by codefox1 - 07-27-2012, 09:43 PM
The speaker table error?
Philco 70 antenna lead
