  • 1 Vote(s) - 5 Average
Now I've done it...One Bucket List set FOUND!
#31
You are exactly right-The scotts mostly prior to 1937 were not undercoated. That is the secret to a good chrome plating. I used to work in a factory that plated chrome cylinder rods and we used a nickel undercoating.
The late 1930's Scotts seem to be much better in their plating but I don't know if they changed their process or what. Maybe a new supplier perhaps.
RE: Now I've done it...One Bucket List set FOUND! - by y2kbruce - 07-28-2012, 09:55 AM
There are currently 9062 online users. [Complete List]
» 2 Member(s) | 9060 Guest(s)
