Identification
+1 Try to do it yourself, it's enjoyable take your time and hands off when power is applied. In the end you should wind up with a nice radio that will play for many decades.
Believe us, unless a super rare model in original museum condition, you will not be able to make a dime on it, even if you got if for free.
Identification - by Lane - 07-25-2012, 09:59 AM
RE: Identification - by codefox1 - 07-25-2012, 11:11 AM
RE: Identification - by Chuck Schwark - 07-25-2012, 11:37 AM
RE: Identification - by Ron Ramirez - 07-25-2012, 11:41 AM
RE: Identification - by TA Forbes - 07-25-2012, 02:52 PM
RE: Identification - by Steve Davis - 07-25-2012, 06:20 PM
RE: Identification - by 7estatdef - 07-25-2012, 09:27 PM
RE: Identification - by TA Forbes - 07-25-2012, 09:44 PM
RE: Identification - by Lane - 07-27-2012, 08:06 AM
RE: Identification - by Arran - 07-28-2012, 01:13 AM
RE: Identification - by codefox1 - 07-28-2012, 12:06 PM
RE: Identification - by 7estatdef - 07-28-2012, 05:51 PM
RE: Identification - by Lane - 07-28-2012, 09:32 PM
RE: Identification - by Ron Ramirez - 07-29-2012, 06:58 AM
Philco 91 Tuning Condenser
There are currently 5516 online users. [Complete List]
» 1 Member(s) | 5515 Guest(s)
