Philco 16 Chassis - Cabinet?
I picked up this Philco at an estate sale today for $40. The chassis looks like a model 16 but I have not seen this cabinet before. It's in good shape and may not need to be refinished except perhaps on the top.
Steve Chambers
[Image: http://i614.photobucket.com/albums/tt228...G_9086.jpg]
[Image: http://i614.photobucket.com/albums/tt228...G_9087.jpg]
Philco 16 Chassis - Cabinet? - by Steve Chambers - 07-28-2012, 04:24 PM
RE: Philco 16 Chassis - Cabinet? - by Eric T - 07-28-2012, 04:52 PM
RE: Philco 16 Chassis - Cabinet? - by y2kbruce - 07-28-2012, 04:54 PM
RE: Philco 16 Chassis - Cabinet? - by Ron Ramirez - 07-28-2012, 05:20 PM
RE: Philco 16 Chassis - Cabinet? - by Ron Ramirez - 07-28-2012, 09:20 PM
RE: Philco 16 Chassis - Cabinet? - by TA Forbes - 07-29-2012, 12:47 PM
RE: Philco 16 Chassis - Cabinet? - by Arran - 07-29-2012, 08:25 PM
RE: Philco 16 Chassis - Cabinet? - by Ron Ramirez - 07-30-2012, 12:06 PM
RE: Philco 16 Chassis - Cabinet? - by Arran - 07-30-2012, 06:27 PM
RE: Philco 16 Chassis - Cabinet? - by codefox1 - 07-31-2012, 08:10 PM
RE: Philco 16 Chassis - Cabinet? - by Steve Davis - 07-31-2012, 08:59 PM
RE: Philco 16 Chassis - Cabinet? - by Arran - 08-02-2012, 12:05 AM
Philco 91 Tuning Condenser
