Philco 16 Chassis - Cabinet?
Ron:
I suspected as much. Who would have applied the Philco decal? The cabinet maker or perhaps the dealer?
Steve Chambers
Philco 16 Chassis - Cabinet? - by Steve Chambers - 07-28-2012, 04:24 PM
RE: Philco 16 Chassis - Cabinet? - by Eric T - 07-28-2012, 04:52 PM
RE: Philco 16 Chassis - Cabinet? - by y2kbruce - 07-28-2012, 04:54 PM
RE: Philco 16 Chassis - Cabinet? - by Ron Ramirez - 07-28-2012, 05:20 PM
RE: Philco 16 Chassis - Cabinet? - by Steve Chambers - 07-28-2012, 09:03 PM
RE: Philco 16 Chassis - Cabinet? - by Ron Ramirez - 07-28-2012, 09:20 PM
RE: Philco 16 Chassis - Cabinet? - by TA Forbes - 07-29-2012, 12:47 PM
RE: Philco 16 Chassis - Cabinet? - by Arran - 07-29-2012, 08:25 PM
RE: Philco 16 Chassis - Cabinet? - by Ron Ramirez - 07-30-2012, 12:06 PM
RE: Philco 16 Chassis - Cabinet? - by Arran - 07-30-2012, 06:27 PM
RE: Philco 16 Chassis - Cabinet? - by codefox1 - 07-31-2012, 08:10 PM
RE: Philco 16 Chassis - Cabinet? - by Steve Davis - 07-31-2012, 08:59 PM
RE: Philco 16 Chassis - Cabinet? - by Arran - 08-02-2012, 12:05 AM
Philco 91 Tuning Condenser
There are currently 5865 online users. [Complete List]
» 3 Member(s) | 5862 Guest(s)
