Philco 15X-Cabinet questions
I didn't know that the 1932 Philcos had water soluble on the dials? I thought that was more of a problem with the 1936-38 dials? The dial on the 90 chassis I have is fine, which is a 1931 set, and the one on my 3118 is fine and it's a 1934 set, it also came from a damp basement.
Philco 15X-Cabinet questions - by Radioguy52 - 07-29-2012, 10:42 AM
RE: Philco 15X-Cabinet questions - by Ron Ramirez - 07-29-2012, 12:00 PM
RE: Philco 15X-Cabinet questions - by Arran - 07-29-2012, 08:47 PM
RE: Philco 15X-Cabinet questions - by Ron Ramirez - 07-29-2012, 08:55 PM
RE: Philco 15X-Cabinet questions - by Radioguy52 - 07-30-2012, 09:44 AM
RE: Philco 15X-Cabinet questions - by Ron Ramirez - 07-30-2012, 09:58 AM
RE: Philco 15X-Cabinet questions - by Radioguy52 - 07-30-2012, 12:09 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
There are currently 1634 online users. [Complete List]
» 3 Member(s) | 1631 Guest(s)
