Philco 60 Hum problem
I recapped this Philco awhile back. Sounded fine, but now it has developed an AC hum and lost all reception. I have by-passed and checked both filters and they are fine. If I put my probes on the 42's K and P, no scratching in the speaker. Any suggestions? Also, my Riders says with Run# 7 resistor #19, part # 4518 (5,000 ohm) should be changed to a 99,000 ohm. My schematic shows that resistor #19 is a 51,000 ohm. Any help there as well.
Thanks in advance.
Bill
Philco 60 Hum problem - by Guest - 04-13-2007, 08:22 PM
Model 60 Hum - by Guest - 07-28-2007, 02:22 PM
91H Code 126 Restore
There are currently 5571 online users. [Complete List]
» 1 Member(s) | 5570 Guest(s)
