Philco 15X-Cabinet questions
Ron. Thanks for the detailed answer. I plan on useing Mohawk perfect brown. A follow up on the results of stripping the laquer and stain with a 50/50 mix.. Will that remove the decorative gold painted lines that trim the top .. Will that come off? Or is there a better way to avoid , and will the perfect brown cover it ? Maybe masking before stripping and light stain? On that trim art area..
Philco 15X-Cabinet questions - by Radioguy52 - 07-29-2012, 10:42 AM
RE: Philco 15X-Cabinet questions - by Ron Ramirez - 07-29-2012, 12:00 PM
RE: Philco 15X-Cabinet questions - by Arran - 07-29-2012, 08:47 PM
RE: Philco 15X-Cabinet questions - by Ron Ramirez - 07-29-2012, 08:55 PM
RE: Philco 15X-Cabinet questions - by Radioguy52 - 07-30-2012, 09:44 AM
RE: Philco 15X-Cabinet questions - by Ron Ramirez - 07-30-2012, 09:58 AM
RE: Philco 15X-Cabinet questions - by Radioguy52 - 07-30-2012, 12:09 PM
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2494 online users. [Complete List]
» 4 Member(s) | 2490 Guest(s)
AvatarAvatarAvatarAvatar
