Philco 89
Hi all
I ran across a Philco 89 today, he wanted $50 for it. The cabinet is solid some veneer is missing on top, the rest of the cabinet is good. It will
have to be refinished. All knobs are on it and the chassis is clean. Is $50 a ok price?
Joe Icon_think
Philco 89 - by w4rtc - 07-30-2012, 05:26 PM
RE: Philco 89 - by 7estatdef - 07-30-2012, 06:36 PM
RE: Philco 89 - by Arran - 07-30-2012, 06:52 PM
RE: Philco 89 - by Ron Ramirez - 07-30-2012, 07:35 PM
Philco 91 Tuning Condenser
