Help with Troubleshooting on a Philco 71
You might have an open coil. That was the problem with mine. The primary of the oscillator coil was open and I had to rewind it. These sets and the 60 series sets were known for open coils. Ohm them all out. I bet you find one open.
-Keith
RE: Help with Troubleshooting on a Philco 71 - by ipwizard - 07-31-2012, 09:21 PM
The speaker table error?
Philco 70 antenna lead
