Big HEAVY lots of tubes - for 1931
Looks like we will be working on the same chassis. Have not started on mine yet, but here is a link to the introduction. Another couple weeks and off I go on it. One other project to finish that I started 30 years ago.
Jerry
http://philcoradio.com/phorum/showthread.php?tid=4953
RE: Big HEAVY lots of tubes - for 1931 - by jerryhawthorne - 08-01-2012, 01:05 AM
Philco 91 Tuning Condenser
