Help with Troubleshooting on a Philco 71
If the mica is too much trouble to handle, buy a trim cap, and solder it instead.
Won't even be that noticeable.
RE: Help with Troubleshooting on a Philco 71 - by morzh - 08-01-2012, 11:52 AM
The speaker table error?
Philco 70 antenna lead
