battery pack for Philco 39-85 121
Tank, give us a report on your tube filament situation. Do they all look good on your meter? Even flush with the tube, you may be able to get a connection. No need to try if the filament is open.
You can post here in the for sale forum for tubes if you need them. Good prices and reliable people.
Jerry
battery pack for Philco 39-85 121 - by Tank - 07-27-2012, 04:34 PM
RE: battery pack for Philco 39-85 121 - by Tank - 08-01-2012, 03:47 PM
RE: battery pack for Philco 39-85 121 - by Tank - 08-02-2012, 12:15 AM
RE: battery pack for Philco 39-85 121 - by jerryhawthorne - 08-02-2012, 12:39 AM
The speaker table error?
Philco 70 antenna lead
