Big HEAVY lots of tubes - for 1931
Recap and recarbon is in order. Hey I just added to jargon. Don't tell the newbies.
RE: Big HEAVY lots of tubes - for 1931 - by codefox1 - 08-02-2012, 11:20 AM
Philco 91 Tuning Condenser
