Philco Tropic Model 42-760T
Welcome, Kathleen! Can you tell us more about your 42-760? Any photos?
I just noticed that I posted the "stripped" photo of my 42-761 nearly three months ago, and since then the only thing I have done to it is to glue one area that was coming loose, and to completely sand it down in preparation for grain fill. This summer has not been as ambitious for me as last summer was as far as refinishing cabinets goes, mainly due to the heat wave.
Philco Tropic Model 42-760T - by Arran - 02-10-2012, 02:42 AM
RE: Philco Tropic Model 42-760T - by Arran - 03-28-2012, 11:44 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 03-29-2012, 05:52 PM
RE: Philco Tropic Model 42-760T - by Arran - 03-29-2012, 07:34 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 03-29-2012, 08:05 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 05-17-2012, 07:16 PM
RE: Philco Tropic Model 42-760T - by kathleen550 - 08-01-2012, 09:08 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 08-02-2012, 11:43 AM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 08-21-2012, 03:58 PM
Re: Philco Tropic Model 42-760T - by Ron Ramirez - 02-10-2012, 06:48 AM
Re: Philco Tropic Model 42-760T - by Sean - 02-10-2012, 11:15 AM
Re: Philco Tropic Model 42-760T - by PhilcoMike - 02-10-2012, 11:42 AM
Re: Philco Tropic Model 42-760T - by Ron Ramirez - 02-10-2012, 01:31 PM
Re: Philco Tropic Model 42-760T - by TA Forbes - 02-10-2012, 03:14 PM
Re: Philco Tropic Model 42-760T - by Ron Ramirez - 02-10-2012, 07:53 PM
Re: Philco Tropic Model 42-760T - by Doug Houston - 02-10-2012, 10:24 PM
Re: Philco Tropic Model 42-760T - by Arran - 02-11-2012, 12:52 AM
Re: Philco Tropic Model 42-760T - by Arran - 02-11-2012, 01:22 AM
Re: Philco Tropic Model 42-760T - by Doug Houston - 02-11-2012, 01:51 AM
Re: Philco Tropic Model 42-760T - by Arran - 02-11-2012, 02:06 AM
Philco 91 Tuning Condenser
There are currently 5910 online users. [Complete List]
» 3 Member(s) | 5907 Guest(s)
