Philco Tropic Model 42-760T
Actually, it is probably a 42-788T. Do you know anything about that model? .....Including, generally, a range of how much it might be worth in very good physical condition. ....Probably needs tube relacements.
I don't have a picture of our set, as it is at my Brother's house. They are currently out of town, so I can't verify that it is a '41 or '42 or get a
picture right now.
Philco Tropic Model 42-760T - by Arran - 02-10-2012, 02:42 AM
RE: Philco Tropic Model 42-760T - by Arran - 03-28-2012, 11:44 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 03-29-2012, 05:52 PM
RE: Philco Tropic Model 42-760T - by Arran - 03-29-2012, 07:34 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 03-29-2012, 08:05 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 05-17-2012, 07:16 PM
RE: Philco Tropic Model 42-760T - by kathleen550 - 08-01-2012, 09:08 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 08-02-2012, 11:43 AM
RE: Philco Tropic Model 42-760T / 42-788T - by kathleen550 - 08-02-2012, 12:32 PM
RE: Philco Tropic Model 42-760T - by Ron Ramirez - 08-21-2012, 03:58 PM
Re: Philco Tropic Model 42-760T - by Ron Ramirez - 02-10-2012, 06:48 AM
Re: Philco Tropic Model 42-760T - by Sean - 02-10-2012, 11:15 AM
Re: Philco Tropic Model 42-760T - by PhilcoMike - 02-10-2012, 11:42 AM
Re: Philco Tropic Model 42-760T - by Ron Ramirez - 02-10-2012, 01:31 PM
Re: Philco Tropic Model 42-760T - by TA Forbes - 02-10-2012, 03:14 PM
Re: Philco Tropic Model 42-760T - by Ron Ramirez - 02-10-2012, 07:53 PM
Re: Philco Tropic Model 42-760T - by Doug Houston - 02-10-2012, 10:24 PM
Re: Philco Tropic Model 42-760T - by Arran - 02-11-2012, 12:52 AM
Re: Philco Tropic Model 42-760T - by Arran - 02-11-2012, 01:22 AM
Re: Philco Tropic Model 42-760T - by Doug Houston - 02-11-2012, 01:51 AM
Re: Philco Tropic Model 42-760T - by Arran - 02-11-2012, 02:06 AM
Philco 91 Tuning Condenser
There are currently 5178 online users. [Complete List]
» 1 Member(s) | 5177 Guest(s)
