Big HEAVY lots of tubes - for 1931
Thanks Phlogiston, sorry to hear all gummy with tar. I do believe I will try the method of using a drill from underneath to break the wires from in inside going out to the connection point and leaving the base attached. Then on to the spot welds to see if I can lift the removal top with the base attached to the chassis. Worked great on 112 can.
Jerry
RE: Big HEAVY lots of tubes - for 1931 - by jerryhawthorne - 08-02-2012, 02:46 PM
Philco 91 Tuning Condenser
