O K what is it
Interesting how the chassis has multiple holes punched bellow the dial, obviously this chassis was designed to accomodate several different cabinets. Waht is also interesting is that it is an AC transformer set in a Bakelite cabinet, did the Lafayette also have a power transformer? The shape of the cabinet reminds me of a Tesla Talisman, except that it is likely older and is American made.
O K what is it - by w4rtc - 08-03-2012, 11:28 PM
RE: O K what is it - by gary rabbitt - 08-04-2012, 12:45 AM
RE: O K what is it - by Arran - 08-04-2012, 04:43 AM
RE: O K what is it - by Ron Ramirez - 08-04-2012, 08:35 AM
RE: O K what is it - by Arran - 08-04-2012, 08:50 AM
RE: O K what is it - by w4rtc - 08-04-2012, 11:13 AM
RE: O K what is it - by rocketeer - 08-04-2012, 05:50 PM
RE: O K what is it - by codefox1 - 08-04-2012, 05:52 PM
RE: O K what is it - by w4rtc - 08-04-2012, 09:20 PM
RE: O K what is it - by rocketeer - 08-04-2012, 09:40 PM
RE: O K what is it - by codefox1 - 08-04-2012, 10:01 PM
Philco 91 Tuning Condenser
There are currently 6922 online users. [Complete List]
» 1 Member(s) | 6921 Guest(s)
