Re Capping
Agree with Chuck on this one. Usually don't replace mica unless there's an alignment problem. The '50 IF xformers are called K Tran their 3/4x 3/4x 2 1/2" usually 455kc.
Re Capping - by Dick Finn - 08-03-2012, 03:24 PM
RE: Re Capping - by Dave - 08-03-2012, 03:42 PM
RE: Re Capping - by DeckApe - 08-03-2012, 04:20 PM
RE: Re Capping - by Dick Finn - 08-03-2012, 05:32 PM
RE: Re Capping - by chucka - 08-04-2012, 11:03 AM
RE: Re Capping - by Phlogiston - 08-04-2012, 01:02 PM
RE: Re Capping - by marv - 08-04-2012, 07:42 PM
RE: Re Capping - by 7estatdef - 08-04-2012, 08:00 PM
RE: Re Capping - by codefox1 - 08-04-2012, 09:54 PM
RE: Re Capping - by Dick Finn - 08-04-2012, 11:27 PM
RE: Re Capping - by chucka - 08-05-2012, 07:58 AM
RE: Re Capping - by exray - 08-05-2012, 08:48 AM
RE: Re Capping - by Phlogiston - 08-05-2012, 09:40 AM
RE: Re Capping - by Dick Finn - 08-05-2012, 10:01 AM
RE: Re Capping - by Arran - 08-06-2012, 05:35 AM
RE: Re Capping - by exray - 08-06-2012, 06:53 AM
The speaker table error?
Philco 70 antenna lead
