Re Capping
Well, sorta. Molded capacitors of larger values from most any manufacturer are likely to be paper. Be suspicious with anything higher than, say, .002 (2000pf). Any over .005 (5000pf) are almost always paper.
Re Capping - by Dick Finn - 08-03-2012, 03:24 PM
RE: Re Capping - by Dave - 08-03-2012, 03:42 PM
RE: Re Capping - by DeckApe - 08-03-2012, 04:20 PM
RE: Re Capping - by Dick Finn - 08-03-2012, 05:32 PM
RE: Re Capping - by chucka - 08-04-2012, 11:03 AM
RE: Re Capping - by Phlogiston - 08-04-2012, 01:02 PM
RE: Re Capping - by marv - 08-04-2012, 07:42 PM
RE: Re Capping - by 7estatdef - 08-04-2012, 08:00 PM
RE: Re Capping - by codefox1 - 08-04-2012, 09:54 PM
RE: Re Capping - by Dick Finn - 08-04-2012, 11:27 PM
RE: Re Capping - by chucka - 08-05-2012, 07:58 AM
RE: Re Capping - by exray - 08-05-2012, 08:48 AM
RE: Re Capping - by Phlogiston - 08-05-2012, 09:40 AM
RE: Re Capping - by Dick Finn - 08-05-2012, 10:01 AM
RE: Re Capping - by Arran - 08-06-2012, 05:35 AM
RE: Re Capping - by exray - 08-06-2012, 06:53 AM
The speaker table error?
Philco 70 antenna lead
