38-690 audio problem
Are there any documents available that describe the theory of operation of the audio section on the 38-690?
I have one on the bench, with one issue remaining, no appreciable voltage level out of the tweeter transformer winding. Tuning a local station and adjusting the volume for annoyingly loud output I still only measure 500mv to 800mv p-p output.
I've injected audio into the 6R7 grid at various frequencies and have good levels on the 6L6 grids, but still only millivolts on the tweeter winding.
I did find that the "whistle" filter now has the notch at 10.8KHz
Any help appreciated.
Chuck
38-690 audio problem - by chucka - 08-05-2012, 12:57 PM
RE: 38-690 audio problem - by morzh - 08-05-2012, 02:22 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-05-2012, 04:15 PM
RE: 38-690 audio problem - by chucka - 08-06-2012, 12:44 AM
RE: 38-690 audio problem - by codefox1 - 08-06-2012, 11:02 AM
RE: 38-690 audio problem - by Ron Ramirez - 08-06-2012, 03:51 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-08-2012, 08:08 PM
RE: 38-690 audio problem - by chucka - 08-25-2012, 05:25 PM
RE: 38-690 audio problem - by chucka - 09-08-2012, 09:45 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-08-2012, 11:09 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-09-2012, 09:46 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-09-2012, 01:34 PM
RE: 38-690 audio problem - by chucka - 09-10-2012, 10:17 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 10:57 PM
RE: 38-690 audio problem - by chucka - 09-13-2012, 11:25 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 11:41 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-14-2012, 05:47 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 07:46 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 02:46 PM
RE: 38-690 audio problem - by Diverted - 03-17-2015, 11:32 AM
