38-690 audio problem
Ron,
Yes I had seen the service note and made those mods.
Resistance readings on the transformer:
Winding_________Measured___________Schematic
Primary__________850 ohms___________475 ohms
6L6 Grid #1______270 ohms____________260 ohms
6L6 Grid #2______287 ohms____________260 ohms
Tweeter___________8 ohms______________???
Primary seems way high unless the schematic is wrong, tweeter winding, don't know, can anyone take reading on a known good set and check against my reading?
I did manage to redraw and simplify the complete audio circuit from 1st AF to speakers and believe I have a good idea on how the system works.
I was curious if there was a theory of operation paper somewhere.
Chuck
38-690 audio problem - by chucka - 08-05-2012, 12:57 PM
RE: 38-690 audio problem - by morzh - 08-05-2012, 02:22 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-05-2012, 04:15 PM
RE: 38-690 audio problem - by chucka - 08-06-2012, 12:44 AM
RE: 38-690 audio problem - by codefox1 - 08-06-2012, 11:02 AM
RE: 38-690 audio problem - by Ron Ramirez - 08-06-2012, 03:51 PM
RE: 38-690 audio problem - by Ron Ramirez - 08-08-2012, 08:08 PM
RE: 38-690 audio problem - by chucka - 08-25-2012, 05:25 PM
RE: 38-690 audio problem - by chucka - 09-08-2012, 09:45 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-08-2012, 11:09 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-09-2012, 09:46 AM
RE: 38-690 audio problem - by jerryhawthorne - 09-09-2012, 01:34 PM
RE: 38-690 audio problem - by chucka - 09-10-2012, 10:17 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 10:57 PM
RE: 38-690 audio problem - by chucka - 09-13-2012, 11:25 PM
RE: 38-690 audio problem - by jerryhawthorne - 09-13-2012, 11:41 PM
RE: 38-690 audio problem - by Ron Ramirez - 09-14-2012, 05:47 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 07:46 AM
RE: 38-690 audio problem - by chucka - 09-14-2012, 02:46 PM
RE: 38-690 audio problem - by Diverted - 03-17-2015, 11:32 AM
