Big HEAVY lots of tubes - for 1931
First coats of lacquer going on the cabinet now.
RE: Big HEAVY lots of tubes - for 1931 - by Phlogiston - 08-08-2012, 12:56 PM
Philco 91 Tuning Condenser
