620 electrolytics
Hi GilBenn
Capacitor can (67) is a dual 8-8 uF unit. The original was rated 475 volts each section!
I would not use less than 10 uF, 450 WVDC; 500 WVDC would be better as a safety factor. True, the input filter is not likely to see more than 350-400, but I would rather be safe than sorry...power transformers aren't cheap!
The single can was originally 16 uF, 400 WVDC. 22 uF, 450 WVDC would be an ideal replacement.
620 electrolytics - by GilBenn - 08-09-2012, 12:14 PM
RE: 620 electrolytics - by Sparks_Radio - 08-09-2012, 03:22 PM
RE: 620 electrolytics - by Ron Ramirez - 08-09-2012, 04:09 PM
Philco 91 Tuning Condenser
