Philco 80jr alignment procedure.
Also check rivets that are used for ground connections.
Philco 80jr alignment procedure. - by morzh - 08-04-2012, 11:38 PM
RE: Philco 80jr alignment procedure. - by morzh - 08-05-2012, 10:30 AM
RE: Philco 80jr alignment procedure. - by morzh - 08-07-2012, 09:28 PM
RE: Philco 80jr alignment procedure. - by morzh - 08-09-2012, 07:56 PM
RE: Philco 80jr alignment procedure. - by morzh - 08-09-2012, 11:04 PM
RE: Philco 80jr alignment procedure. - by 7estatdef - 08-10-2012, 05:39 PM
RE: Philco 80jr alignment procedure. - by morzh - 09-08-2012, 07:54 PM
RE: Philco 80jr alignment procedure. - by morzh - 09-13-2012, 01:26 PM
The speaker table error?
Philco 70 antenna lead
