Philco 111 grommet question
Can anyone suggest a source and p/n for the chassis mounting grommets for my 111 restoration? Three are in little pieces and one is missing. Thanks for your help. Getting ready to start on the project.
Jerry
Philco 111 grommet question - by jerryhawthorne - 08-10-2012, 07:42 PM
RE: Philco 111 grommet question - by Phlogiston - 08-11-2012, 01:29 AM
RE: Philco 111 grommet question - by ipwizard - 08-11-2012, 05:49 PM
RE: Philco 111 grommet question - by Eric T - 08-16-2012, 08:23 PM
RE: Philco 111 grommet question - by codefox1 - 08-16-2012, 08:42 PM
Philco 91 Tuning Condenser
There are currently 5398 online users. [Complete List]
» 1 Member(s) | 5397 Guest(s)
