  • 1 Vote(s) - 4 Average
Ron's Cabinet Work for the 2012 Season
#35
Yes, and next time I'll concentrate on getting a smooth surface with Crystalac before thinking about sanding sealer. Looks like it will still take multiple applications unless I glop it on heavily.
This is why I was openly wishing for someone who has experience using this stuff to step forward with a well-illustrated tutorial showing how they achieve good results by merely applying and squeegeeing, or applying and wiping, with no need to sand. I don't believe it, quite frankly, and I won't believe it until/unless I am shown proof of these claims.
RE: Ron's Cabinet Work for the 2012 Season - by Ron Ramirez - 08-12-2012, 07:46 AM
Users browsing this thread: 21 Guest(s)
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
There are currently 2476 online users. [Complete List]
» 4 Member(s) | 2472 Guest(s)
AvatarAvatarAvatarAvatar
