Recap done still no radio
You can find more information from http://www.nostalgiaair.org/
Go to resources, Philco Radio & Television Corp, then look up your model. As stated similar sets that do have voltage charts should give you some good information on what to expect at each stage.
Recap done still no radio - by philco4me - 08-12-2012, 01:22 PM
RE: Recap done still no radio - by Marsupial - 08-12-2012, 04:28 PM
RE: Recap done still no radio - by codefox1 - 08-12-2012, 05:18 PM
RE: Recap done still no radio - by Chuck Schwark - 08-13-2012, 09:32 AM
RE: Recap done still no radio - by philco4me - 08-13-2012, 04:51 PM
RE: Recap done still no radio - by philco4me - 08-13-2012, 06:04 PM
RE: Recap done still no radio - by codefox1 - 08-13-2012, 06:13 PM
RE: Recap done still no radio - by philco4me - 08-13-2012, 06:17 PM
RE: Recap done still no radio - by Eric T - 08-18-2012, 05:44 PM
The speaker table error?
Philco 70 antenna lead
